Ygransom
Turbocharged
that looks right. install is real easy remove fuse from in line fuse holder. Raise tank, remove headlamp from housing. thread battery leads through rear of headlight and route along frame rail to battery. Tie off to frame. Inset headlamp into female plug, install male plug into factory headlight plug. Reinstall ehadlight, lower tank, connect cables to battery, reinstall inline fuse. See where you are going.
Improvement may not be as much as on a standard due to 1 versus 2 headlamps and less damage to factor wires but you will see some.
