Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,732
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
OK for the spring load on the belllville washer is what absorbs impact and allows thing like dogs to slide by and grab. IMO . The question I would be confused on is do you have a splined washer/shim and splined bushings on the second (as per the books out dated drawing) and third gear out put cluster or is the does both bushings have a shoulder face as a part of them which of course is splined? Just trying to see if your bike has been updated since the torsional damper failed which would also have been updated at the same time. Unless the components of the update increased over time!!!!!!!!! Still we are back to incorrect snap ring assembly as a known issue before considering others possibilities!!!!!!!!!!!!
Here is 2nd gear
