Spoke with an Avon Tire Engineer Today
Claviger posed the link to http://www.deget.de/index-2.html
Front rubber - not thought much - Rear - a 200/55-ish. but I'm not going to look much until I decide if the rear conversion is budget-able.
And frankly at the moment - it is not. €720 for R&D hard to justify. I can get another decent gun for that. Well almost
Interesting stuff.
I've just replaced the ME880 (140 section) on the Front of the Rocket. Thought I would try the Avon Cobra.
First impressions straight off, it felt real sweet, but I'm thinking that this is just the difference between a worn tyre and new.
But I don't recall this same "sweetness" when changing tyres in the past, sure the new tyre felt better, but not like this.
My 2cents worth.
Did some data logging today for ****s n giggles. 1500 RPM launch rolling on fast, Avon outback with 40 PSI clicked off a 2.976 second 0-60, on the street and I never hit full throttle, only 90%.
NO SPIN just went like hell. Hard to argue with that, there's definitely a sub 2.5 to be had, I just need to get my 60 foots down better and actually hit 100% throttle.
Sub 3s and I know it was nowhere near my best launch. Just happened to think enough to log it before hand today. I do know at 100% throttle it'll lift the front tire about a foot before going into second and this launch didn't do that so...
@1olbull and @barbagris I got an answer from Deget on converting a 16x8.5 rocket wheel to a 17x8.75 wheel.
After close examination I figured out their method, its quite ingenious. The cut off the lip of the stock rim, then take a new hoop and slide it around the outside. I can only assume they weld them together along the inside of the rim, because there is no weld visible on the wheels they've done and it would make balancing easy, just balance, grind, balance grind etc until its weighted evenly. It's not likely to ever fail, or leak, and doesn't require precision machining that would be involved in cutting off the whole hoop and mating another one.
Price came out to - 780 euros for the work, using a forged aluminum hoop to increase the diameter for strength.
Shipping to me was quoted around 140 euros if a tire is installed, so a bit less without.
In the US we can pass on the TUV certification, meaning you save 60 euros.
Roughly translates to $980 shipped for a 17x8.75. As a 17 you can now fit the Pilot Power 3, a tire literally unmatched as a street tire if you consider both wet and dry traction. If you go 18x8.75, you get the Dunlop Q3 as an option, wears much faster than PP3, has less rain grip, but has significantly increased dry grip.
An option would be to buy a rim on ebay.de, have it shippped to them, and then do the work and forward to you. It would save you the downtime while your rim was being worked.
IN EITHER CASE, the PP3 and Q3, are both so vastly superior to the 16x8.5 options, it's irrelevant which you pick unless your planning on racing your R3 on the track, then go with the Q3 lol.
