sonny
Lucked out big time. Had the shims to replace the ones requiring replacement. Should place it around 11MM to 12MM all the way down on the intake side. Real happy about that.
Cam ladder looks good especially after 50,000 miles.
Cam chain tensioner looking good.
Camshaft sprockets Look brand new no wear at all. Just to let you all know if anybody needs a set of stock cams they are yours. Just pay postage. Shined a light down inside and Cam guides are good no need to replace. Just one happy camper all the way around. Torn into Harley engines with the same mileage and found all kinds of problem. Cam chain shot to Shi%. Stretched way out of tolerance. Real glad i followed the man in the tin sheds advice. If i stuck with the original cam chain would have lost all the low end torque. No way would you ever get it set right with a that much stretch. Now here is the trick. A few on here have had problems getting the cam ladder off without screwing up the bolts that hold it in.
Notice picture and cams are in the same position. Very lightly loosen bolts starting from the center. Then go back to center and loosen again working your way out. Took three times around. Time consuming yes but bolts have no wear or tear from removing. Follow the manual on this and your good. No need to align any marks yet. Simple and easy to do.
Gee mom no cams. Small screwdriver works rather well pulling out old shims from buckets by the way. Real small screwdriver. Slow and easy. No foot race at all.
