That would be 5 hp maybe ? Nels has had the new WINPEP 8 upgrade, which we all must get eventually as the hardware is no longer supported.I have my name down for the module. The tech guy here in OZ swears black and blue it will read the same. I will test it. What concerns me is , if it is different , I will have 20 years of data which I cannot compare...
@Neville Lush ,
I had my bike dynod at nels using winpep 8, then a week later using winpep 7 at a different shop. Numbers were within what is expected when I was validating my new muffler didnt rob any power, winpep 7 read out right about 10hp higher aka 5%.
Tuneboy set to 7000 RPM limit.
On the graphs:
Winpep 8 dyno reports redline at 6700, 5 pulls personally observed, all cut out at 6700 bouncing off fuel cut.
Winpep 7 dyno reports redline at 7000, 3 pulls personally observed, all cut out at 7000 bouncing off fule cut.
That works out to roughly 5%, which, is right around the HP delta between the two on numerous bikes according to Nels. There were NO changes to the tuneboy tune between the two dynos.
I suspect delta between the two might be based on the RPM readout and not the math algorithm behind the front end. Power commander reports redline occurs at 7100, Triumph ECU reports it right at 7000.
Both dyno operators used the coil wire as a pickup on cylinder 1.
Who knows whats going on, its quite weird tbh. Definitely something they need to sort out though, because if the RPM readout is off, I don't need to explain to you of all people what the impact potential is.
