The infamous starter click
Rocket Scientist
Grand Exulted Poobah
Spring Lake, Michigan
Black 05' Rocket III standard
At the end of 2023 my starter was doing the "click" badly. Sometimes it would take 4 or 5 stabs to get it to start. Last winter I installed a relay that takes power straight from the battery to the start solenoid. I did nothing else. I just thought about it today. It hasn't done the click one time this riding season. I think it's cured 😀
long time ago i installed two relays to take the current out of the ignition and so i taught why not put the starter relay to battery so i did that.
similar to what the rocket scientist did and since then i have never had a click problem. actually i never had a problem before i have had several no click problems like clutch switch dirty that seemed to work if i let out the lever slowly and when i had some spare time i wd40 it. and the starter button and what i did was push hard on the button and tried to wiggle it. one pf these years i need to take it apart and clean it.
hth
