Makes sense what you said have bike on ,select blah blah, then hit record which is what I did (think?) Yesterday. Instruction clearly state otherwise.the more sensors/data selected the slower it works
for example the trans makes the 1-2 shift (u can feel it ) then 1 or 2 seconds latter it shows up on scanner the more info on scanner the slower it works.
for example when it stalls the scanner may show 2200 rpm.
by having the rpm and the speedo sensors u could show the dealer that it is stalling.
now u have the code prob so in my bussiness u fix the clutch code problem and see if that fixes the other prob.
sometimes we have to back out of scanner and start over to get it to work.
i would say make sure ign is in run position and u r getting (reading) the info like tps/rpm ect before trying to hit record and try to select other sensors one at a time.
and no i have not read the instructions. going on what we do with our scanners.
Will try again soon.
