my opinion is that everyone is right they should use the system that they like.
the emergency kill button is for when the throttle sticks open. because when the throttle sticks open in first it goes from 0 to 60 in about 3 seconds so you better know where the kill switch is or for those that are hard core i am sure you could reach the ign switch with the throttle open or you could just pull in the clutch and listen to the engine rev.
it does not make a difference to the comp whether the ign switch or the kill button is used to turn it off they both cut power to comp. the side stand switch cut the signal to the comp and the comp cuts power to the apply side of the engine management relay. you would probably be old and gray before you damaged the comp using the side stand for killing the engine.
every method has its draw backs
kill switch** leaving the ign on and forgetting to put down the stand
side stand**leaving the ign
ign switch**forgetting to put down the stand and a small chance of letting it fall while your reaching for the switch. not being familar with the kill switch if the throttle sticks open.
what was the question? oh i use the kill button and i have left the ign on and it cost me a battery and about an hour shiit. the second time i left it on it took out the ground side of the headlight circuit but that might have been a good thing being the it happen at my shop in stead in the middle of nowhere at night.
also i let it fall over at the gas pump and pined me and broke my shield.
my opinion is do what works for you because you are the one that matters.
