Michelin Commander 11
Tire psi? Frequent tire psi check? Burn outs?
That few miles always puzzles me.
Road surface, lean angle, type of riding. I've never ever done a burnout (stupid), check psi and also have FOBO to monitor tires. I get 4,000/tire and change them 3X/year. My tires wear evenly from edge to edge, not just in the middle. We are equally puzzled how someone can get 10,000 + miles from a tire on such a fast and heavy performance machine.
I'm puzzled too!🤔
Weight of rider? I weigh 172 lbs dry.
I don't see a rear option for the Roadster, but just bought the Michelin Commander III Cruiser Front Motorcycle Tire 140/75R-17 (67V) for the front and will be mounting it soon. Pricey at just over $200 from Rocky Mountain compared to Dunlop Elite (my go to) and Cobra Chromes. Anyone else running this tire on the front?
Since we have the worst roads here in Tucson I have ever ridden on, don't think road surface has much affect.
I do not use the engine to slow me down approaching lights etc, I put it in neutral and coast using both brakes. Tried briefly the other way but too busy for me.. Most people use the engine so maybe that is why. You think?
That could be a factor, as I use downshifting to keep the motor at an ideal RPM. We have super curvy roads here, so if you are riding even moderately hard I think you have to do that. Accelerating out of the curves also contributes. On many of the roads here it's virtually a non-stop process of accelerating and downshifting/braking, i.e. if you're not enjoying the scenery. I'm not the only one in this area, obviously, with similar tire mileage and wear (@Dr.D, and others). See @Paul Bryant on "chicken stripes" here... Chicken stripes??
We have super curvy roads here, so …….On many of the roads here it's virtually a non-stop process of accelerating and downshifting/braking, i.e. if you're not enjoying the scenery. I'm not the only one in this area, obviously, with similar tire mileage and wear.
That’s is a fact. Rubber is scrubbing off all day long either on the the throttle or the brake. If I’m cruising at a steady speed it’s a boring road that I have to take to get to the good stuff. I buy tires to throw them away.
