Fuel pump replacement with non genuine one ?
RocketT
Standard Bore
06 Rocket Classic
Hi all I have to replace my fuel pump and dealer is telling me 6 to 8 wks for a new one so I am looking at replacing it with a non genuine one from eBay has anyone done this before ?
So long as it fits, and it's rated for the proper pressure. Fuel injection uses high pressure, but different systems use differing pressures. But if there is an aftermarket pump that says it will work, well, I'd have no problem.
Toyota RAV4 pump is identical, can get from eBay for about $40 AUD
Like this one for AU $28.90 with FREE postage in Oz
Brand New Intank Fuel Pump&Install Kit For Toyota Camry RAV4 OEM Replacement | eBay
Interestingly the RAV4 specs are similar in size and power output so should be no problem delivering enough fuel/pressure etc.
Variant Engine 2362cc 120KW (Petrol)
Features
38mm compact design with quiet operation
Offset inlet easily to install
Same performance as OE
1 x Fuel Strainer
1 x Universal connector
Technical Data
Min Input Voltage:12V
Flow Rate: 110-120LPH @ 43PSI/12V
Flow Rate: 140-160LPH @ 43PSI/13.5V
Current: 5.0A@43PSI/12V
PRV Activation:0-100PSI
Mechanical Spec
Overall Length (tip to tip): 4 1/2" (11.5cm)
Length of Pump Body Metal Case: 2 5/8" (6.6cm)
Pump Body Diameter: 1 1/2" (3.8cm)
Inlet Diameter: 5/16" (0.8cm)
Outlet Diameter: 5/16" (0.8cm)
The walbro 342 pump does need a small amount of work to the fuel hose exiting the pump to get it to fit as it is approx 1/2 inch longer. You may need to use the triumph "tea bag" filter as well on the walbro pump. Be cautious of "replacement " pumps as they are often made in china or similar and can be poor copies... Also the pressure is determined by the REGULATOR not the pump. The pump supplies volume. Your pressure should be 42psi or very near.
