DEcosse
If it's no Scottish it's CRAP!
Your kit (and others from recently) has the connection made in a different location John, so most will not be able to help you with a picture
The description in the install guide should give a pretty well-defined identity I would have thought:
Here's a picture but it probably does not help much more vs the description - it should be fairly obvious if you just follow the harness down from the left switch on the bar.
As it says in the guide (and above) it will probably be easier to access the Black Wire on the Switch side of the connector rather than the Orange/Black on the Main Harness side (but either will work )
Note that for this example, the user connected to the black wire side of the connector
In this image you can't really see the connector itself, hence the description to follow it from the bar.
There is one free Orange Wire from the alarm connector – this is for the Clutch Switch Trigger & will be connected at Black/Orange wire at the Main Harness connector which mates to the Left-Bar-Switch – important that you positively identify the correct wire! This connector will be located just behind the steering head (follow the cable harness from the Left Bar-Switch till you meet the connector. The Black/Orange Wire will be on the Main Harness side of that connector set (note that alternatively you can connect to the Black Wire that is opposite the Black/Orange wire on the Switch Harness Side, if that is more accessible. The Orange Wire will be connected using the supplied PosiTap.
