Hi Hans - you getting used to life back out of the fast lane again?
I can provide another auxiliary output from the Controller that is active when the remote is within range (which means you don't have to actually set the ignition, just be next to the bike)
But the remote itself does not have the ability to control an accessory output, so you need a switch on the bike.
The simplest location is where the key-lock itself would go
On my Daytona, I actually mounted the solenoid on the panel where the key-lock was (installed a new dummy cover over it) and located the switch just below that, quite unobtrusively
(you can see it just below the sub-frame rail - almost dead-centre of the pic)
For those without Keyless, you can still retro this, but just have the 'enable' off an ignition source (tail-light or something similar) so that the button is only active with the ignition on.
As I mentioned, with the keyless you can use the enable off that, so you don't actually have to pull the clutch to turn on ignition with that set-up.
(I showed a relay in the video in the earlier post - you probably don't need that)
This is the solenoid I used - used part off Ebay (off a Volvo station wagon as I recall)
But there are lots of choices for this
I chose this one because it was a) compact and b) the parts dismantler cut off the connector so I had that as well c) had a control arm that I figured could adapt to my pull-cable
So just take a look on EBay and see what looks conducive for your Rocket
And looking at the Rocket, I can see you could probably have the solenoid right next to the release with only a short piece of cable (or rod) operating it directly.
i.e. the Solenoid does not have to go where the original key went (although that might be good spot for the switch)
So even ahead of actually getting the KeyLess Hans, this is something you can prep yourself;
just pick up a suitable solenoid and a switch and wire in the interim to an ignition source;
then when you get the keyless you can transfer the power source to the 'disarmed' output of the KeyLess and as described, will then not need to turn ignition on.
You've got things like this -
http://rover.ebay.com/rover/1/705-5...0001&campid=5335943355&icep_item=311045671059 which is a universal type kit
or
http://rover.ebay.com/rover/1/705-5...0001&campid=5335943355&icep_item=221773253504
or something like this -
http://rover.ebay.com/rover/1/705-5...0001&campid=5335943355&icep_item=181793346169
or
http://rover.ebay.com/rover/1/705-5...0001&campid=5335943355&icep_item=321589494481
This next one looks interesting - would be pretty easy to mechanically adapt the pull and looks pretty compact
http://rover.ebay.com/rover/1/705-5...0001&campid=5335943355&icep_item=121693520363
Oh - quick note on the electrical hook-up - if it 'pushes' instead of 'pulls' then reverse the polarity of the connections.
Also note that it needs the spring to 'return' it but the OEM spring on the latch mechanism will be adequate for that.
