warp9.9
Pocałuj mnie w dupę
In the end Hart is happy but the problems his shop had with the install had nothing to do with Carpenter Racing they gave instructions on how to dial the cams so timing is right and if they do not want to perform that vital operation right well its on them. Same with pipes Carpenter states the need for larger pipes to get the claimed HP no matter what kit and if your not going to follow their advice you can not complain about not getting the numbers where they should be. This actually happens quite often when People try to redesign a kit that has been proven to work. Its not just pipes its intake systems also. I can understand how frustrating Bob gets with some of the most lame arse questions. Even when they are funny, picture this a Captain calls and asked if Bob is controlling the compression by lengthening or shortening the rods. No thought about high compression pistons just change the stroke on the pistons that are there.
Funny yet time consuming for somone who is on the clock trying to machine components. Any man can only take so many bucket stupid questions before he responds in kind.
You say word of mouth is enough, Well I suggest you listen to complete word of mouth. In other words listen to the happy customers also as I believe there are more of them then negative. If all you look for is negative **** then that is all you will ever see. Listen to them fellers and you will be on a dark side before long which robs HP while giving you the false feeling you gained in torque
Then you can really waste your money adding power just to have it sucked away.
