Tune ECU Com Problem
Ok mate thanks..
The latest is I got another cable.. RIck was kind enough to even deliver it to my door today
I have just connected the Ricks cable it worked perfectly..which goes to show cheap Ebay Cables don't work, not even after 6 hours of brain racking
I ahve saved my original tune (twice) and used a TuneECU map which is pretty standard..Aftermarket mufflers with Cat.
I just tried it and happy to say the bike still runs but there was no improvment over the original tune + Gipro .
Sooo I have the PCv it arrived today... Cat bypass is ordered from ncyyam.com so I have started what I said I wouldn't do... See I told you Richard it would eat away at me
So Hans what do you recommend I will fit the PCv on Saturday but what tune should I load up first?
Cat is in place TORs are fitted no tripples yet
load the Tors tune I sent you!! it will be a bit rich (but the PCV with auto tune will sort it out) without the Tripples but once you remove the secondaries and fit tripples you better Hang On! seriously though it will be ok as long as you are gentle on the throttle.
The tune that comes loaded in the PCV is a good comprimise tune that will get you up and running I have just printed up a copy of the AFR tables from the TuneECU TOR's tune I sent you and in the next couple of days will transpose them into the PCV Map and send it to you if you are interested.
I think I even have Richard interested in the Tors Tune and I get the feeling there will be a Dobec up for sale to ....something tells me I will be fitting or guiding the fitting of another PCV soon
Oh and order your filters thru Flipmiester he supports the forum, his prices are good and he is the only one that seems to stock the the two little filters you also need
Ok Hans thanks for the support mate good to have.. anything you think is will help just sent to me Ill keep every thing in a special Hans Folder
BTW the PCv tunes are few and the isnt one for the R3 Std just tourer and classic.
Antway I will call you Sat if your around Many Tanks!
No not Saturday please remember I have double shift and need to get as much sleep as possible but happy to chat Sunday
Yeah tune that is in the PCV is not radical but will make run smooth I will send you my more radical version when I have had a chance to PLAY but use the TOR's TuneECU tune I sent you to set up your ECU for a better base tune till then
The cables I have found on ebay say they are not compatible with win 7 64bit systems.....that is what I have. Which cable should Iget. It seems that I have the program properly installd. I can see it but that is about it.
Sorry jetdok I just re read ya post I think the cable would be fine its the driver software that you would need for 64bit sys.
TuneECU should have the driver or just plug the cable into your PC and let windows 7 find the driver that suits.
Win 7 driver worked fine for me..just the **** cable that was faulty..
Hope this helps
If I'm ever in a position where I can own a second rocket one will be off its guts and the other my daily ride but for now although my rocket will always be my favorite I have aspirations for a couple more motorcycles . Probably a street triple as a commuter and then something old school that I can restore to it's former glory .
Sent from my iPhone using Tapatalk
yep pcv kicks arse my machine is smooth and powerful from start to full throttle
i love it
I agree with this.. but I have a question about Factory Ign retarded ..
What is the proceedure for clearing the retardm setting /ECU ?
Can it be done by ourselves or is it a dealer thing ?
Would you know mitch....
