transmission problem update
Hi Patrick, maybe ask your guy to check the balance shaft bearings. Especially if you hear the noise on the rhs rear of the engine. Good luck, as the others say. Hope you find it.
thanks for the input .. never really felt whether or not the slapping came from one side in particular semed both footpegs were equally sensing the slapping but hey!! one extra phone call won't hurt.
ok so it coincides with engine loading at mid revs onward in 4th and 5th, and gets worse with revs.
is your engine modified? does it slip out of 4th and 5th?
Loose timing chain?
loose timing chain ? wouldn't that grenade the valves rather than slapping ? I try to think logical but the frustration is rather omnipresent
my engine has had the neville rush 200 kit it comprise cams, pistons and manual tensioner it does not slip out of 5th or 4th
ok. is there a blip/bog/cough/stutter in the engine's running or rear wheel running when a slap noise occurs?
seems very strange that this issue hasn't left a mark on anything inside the engine...
the 2 occasions i've experienced with a slap/whack noise in engines were when (a) a bolt vibrated loose and got whacked by a pulley spinning and (b) a faulty sprag clutch which would not engage until after the starter was spinning, causing a metallic whack.
no blip no bog/ cough /stutter ' just a strong repetitive slap strongly felt in the footpegs from 2500 rpm on intermittently.
well today saturday 18 th I am told by the maintenance manager that a bushing on the shaft where 5th gear is found has been found severely scored . stay tuned for further info I was there to turn in my moly60 for lubing the drive shaft as they dismantled everything connected to the tranny all the way to the rear wheel. I also wrote to triumph of america to see if they would help covering some of my expenses?????
I've been thinking of your problem. How are the rear wheel bearings? Could they be starting to seize? I know it's a long shot. Good luck.
could be?
but the strong slapping felt through the footpegs would more likely indicate it has to come from the engine block stay tune we shall find eventually I am lucky though my mechanic is truly experienced and he also want to look at the rear end as well I dropped off my last moly60 tube for him to lube the shaft.
I remember my 05 making a banging noise. It turned out to be a torsional spring on the drive shaft if my memory serves me.
