atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 2,982
- Location
- Keller, TX
- Ride
- 17 T-120 Black, 20 Bobber Blk, 22 Speed Triple RS
Saturday 8/28 we worked on the neutral indicator issue. I found the neutral switch located down by the oil level sightglass. I pulled the electrical plug off the indicator tab and gently pulled on the wire. The wire came came out from under the cooling hose and kept coming. Then the broken end appeared. The wire had been pulled apart. Tom got my soldering iron and some shrink wrap. He had the wires reconnected in a couple minutes, however we couldn't fish them thru the way they did at the factory since that would have required disassembling the bike, so we had plenty of slack we just fished it thru behind the alternator and ran it straight down to the tab. Plugged it in and then turned on the ignition switch and great big "N" appeared on the dash. So to verify the problem resolved I started the bike and put the kickstand down. The bike kept running. VIOLA!!
Next we pulled the tank and checked the carb throttle cable seating. It was down as far as it would go, we then noticed the cable housing at the throttle grip was deteriorated and some of the plastic housing has chipped off. We'll try running some WD-40 down the cable to see if the slow response is due to the thing sitting out in the rain for 'awhile.' We got the grab handles installed (I'm leaving off the tail trunk). and Tom took it for a test ride. With the exception of the throttle cable issue, all was well. I'll order a new cable and we'll get that installed this winter when it's not so bloody hot in the garage. Otherwise it's ready for a safety inspection and registration.
