atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 3,032
- Location
- Keller, TX
- Ride
- 17 T-120 Black, 20 Bobber Blk, 22 Speed Triple RS
Tom and family left today for South Padre Island for vacation so I'm without the help I usually have. So today I wanted to see why the bike was idling at 5000 RPM (up 1000 after new plugs installed). I removed the left side coil and looked at the adjusting barrel on the throttle cable. It appeared the barrel was about 2/3 to 3/4 all the way out. I then got my fingers wedged in where I could get a spin on the locking nut and began backing that off. After about 5 minutes of 1/4 turns I jiggled the cable and checked the throttle grip feel. Felt like it was still attached to the carb spring (no play). To see if that was where the problem was I started the bike on full choke and the bike started and idled about 2000 RPM for a few seconds then moved upscale to 3200 RPM and I shut the choke off. The engine RPM dropped to 1100 and sat there purring. OK then. Next will come synchroniztion (where the rubber meets the diaphram). If it won't synch the diaphrams have to be changed out. Luckily that can be done with the carbs in place, so better.
