Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
When you put on TORs and RAMAIR you let the engine breathe more air in per revolution, to match that, you need more fuel. Derestricting the secondaries takes this a step further. COpying the timing table in i3 into i2 and i1 takes this even further, as it needs more fuel to keep the same afr with the extra timing.
If you want mileage, leave it stock or accept that it'll run lean when putting TORs on.
The only way you'll get high mileage with mods is a custom map, no one can write that map over the internet....period. To run lean but safe, the fueling has to be tailored to your specific bike, the cruise area on the freeway. It's easy to adjust the values remotely, but are they right? No way to tell without a dyno or wideband
ALL THAT to say, go buy a PC-V and Autotune, its the only easy way to have perfect control over all this stuff without going to a dyno.
