Van_R3Rider
.060 Over
Which twist? I have uploaded the video.I don't think so. Yours is flatter, mine has a twist. May mean nothing. But that click you speak of might.
To the left of the arrow point at the front going down is like 2 separate parts on mine. An indention making it look a little like a twist. Just does not look the same as yours to me. Have to expand pic. Don't know why.Which twist? I have uploaded the video.
Let us know if it works!I am going to order the parts anyways as they are cheap. Below are details if anybody else is interested.
I will have to wait 3-4 months for the riding season. Keep us posted on your riding results. Just curious to see if your stalling is fixed for good.Let us know if it works!
Will do. As odd as it may be, yours might not have the same cause of stalling since no error code. I think it is though. Symptoms identical and that part affects gas with clutch pulled in.I will have to wait 3-4 months for the riding season. Keep us posted on your riding results. Just curious to see if your stalling is fixed for good.
Try one thing for me in the garage. with bike off, press the clutch lever and hear for the tick sound( that's when the metal part presses/depresses the actual switch. Does it tick with the clutch all the way in or in the middle? That might help us to fix ours. Might need to adjust the bend angle of the metal piece.
That is a possibility for sure if Maurice’s new switch is not sticking like mine.i am going to answer with a guess
i am thinking that the switch is sticking and when u let out the lever the switch sticks while the lever moves out then the switch lets loose and travels with a click at the end.
if it were mine i would (when i got the new parts) spray good with wd40 to see if the switch stops clicking and see if that cures stalling.
the purpose of clutch switch is to send signal to computer (ecu) that the clutch is disengaged.That is a possibility for sure if Maurice’s new switch is not sticking like mine.
I now recall that my Kawasaki ZX14R would rev up a bit with clutch in before coming to stop. It would then lower the revs. That explains the purpose of the clutch switch.
