Speedometer, Display, Warning light went nuts, now everything is dead.
Fuse 11 comes directly from. Battery LONG before the switch - you need to resolve the connection between battery & fuse
You can get that connector at corsa-technic in US; (i gave you direct link earlier in thread) Eastern Beaver is good guy but has minimum order and shipping from Japan
PROBLEM SOLVED!!!
Thanks to this forum and all your suggestions this has been an education!
And with the personal help from Sir DEcosse, the wizard of all Rocket 3's, It WAS the connector from the Positive Battery Terminal to the fuse block. After taking one more look at his schematic, it all became clear what I needed to find. Luckily it was easy to get to once I found it.
There's a big fat and a smaller wire both on the Positive Battery terminal. About 6 inches out from the small wire off the battery is a connector. The tail end of the spade terminal end, was bare. Must have been hitting the frame, and the connector itself had been burned to become brittle. I had to break the thing apart with some pliers to get to the metal joint. For a temporary fix I just soldered the two bare fitting together and taped them up with about 40 wraps. I'll get a connector right quick and do it right.
I can wait a bit on a battery. The dealer said it was new when I bought it. (It sat in the warehouse for 8 months, though).
Here's the final pictures of what I did for future reference should anyone have this issue. Up close and then zooming out to get an idea where the connector sits.
Right now, that wad of tape is where the connector should be.
Okay. I'm happy to say that after taking a lot of things apart and back, everything still works!
Now, next thing is finding where those spark plugs are hidden. :cool:
Thanks ALL!!!!
If you do a search for one of our illustrious members by the name of IDK ,you'll find a complete downloadable manual complete with color diagram.
