Hawk
- Joined
- May 15, 2021
- Messages
- 11
- Ride
- Rocket III Roadster 2015
Thank’s I will orderI have a small Bosch scanner about $100 that works great for reading and clearing codes.
You read the code and Wright down the number then you erace the code/codes if don't erace/clear then most of the time that means you have a problem that is there all the time (easier to deal with).
You need to get tuneecu to deal with problems. There is some threads on this.
Alot of code numbers are in the manuals
Post a code number and you will get help.
A new battery will not turn off the
check engine light
Best to read code/codes and make notes for the future.
Hth
Thnks for the tip will measure it with my multimeter. I have a ctek charger and the connection cable that’s attached to the bike have three diods, green - yellow - red that show the battery charge and if I don’t ride for a week the yellow diod is blinking so I think the the battery is done for. I’ve had the bike for three years and the battery wasn’t new when I bought it and winters get kind of cold here in Sweden.A basic multimeter will get you a long way. You can get those 3 numbers just keeping the multimeter in the battery borne as indicated. The result can point to a bad battery, a battery that needs to be charged or a charging system that is not working properly. Even one of these adapter that show the dc voltage connected to the aux port can get these values for you.
