fastfun
Well I picked these up today...
Before sending out, they are 56 big end 52 small end, smaller nearer engine.
They’re now 58 big end 55.5 small end.
More importantly they’re smoother with no machine work stepping internally anymore with a better finish top to bottom.
New blades are a flawless fit, I’ll definitely need to adjust them to let some air past so it will idle.
The JB weld worked perfectly, can’t feel any change with finger tips between the epoxy and the metal.
There’s just a few small things that could be done to make them even better but I’m going to hold off for now.
$375 shipping included from Maxxbore. You’ll alwmso want to send in the engine rubber to have them worked to match the new 55.5mm diameter.
What way did you fix the blades back again onto the shafts ,preventing dropping the tiny bolts out of the blades?
