EasTexRIII
Will do! In the mean time I've been watching videos about how to use the software and reading the user's guide. My mind is blown by how simple this whole procedure is. Getting $300 quotes to check and adjust the throttle bodies is now laughable seeing how easy the procedure is. I've even seen how I can smooth out my stock tune to make the bike not die so often. I'm excited to play around with it this weekend (within reason so I don't blow up my motor).
Make sure whatever tune you are running change (& save changes) the idle rpm to about 930-950 - Lower idle speeds do not properly flow oil thru the oil system, it needs big drinks
