1olbull
Riding Motor Since 1950
The pegs (feelers are useless) and OEM or TORs exhaust are all too low. You can chamfer the peg ends off and still drag around a twisty and eliminate the chicken strip. The kick bolt and engine guards will drag next.I’ve spent time and money to improve handling to only realise the goal is not real.
I’ve replaced standard fork springs and cartridges with racetech and fitted Wilbers to the rear. Now with an exedra max rear tyre and carbon steel inserts under the roadster pegs to allow them to fold up, I drag the exhaust and foot peg rail on the road.
The R3 roadster ground clearance is the problem, it’s going to limit lean angle before the tyre lets go.
Adding Standard boards will get you another inch or more. Also 13 inch rear shocks will help.
Happy twisty hooning!
