Neville Lush
www.nevillelushracing.com
- Joined
- Feb 26, 2007
- Messages
- 1,042
- Location
- Victor Harbor South Australia
- Ride
- Speed Triple 1050 Dirt Track sidecar,H2750Roadrace sidecar W800 Kawasaki
I have had the same scenario before and once again last week. The owner had bought a new MAP sensor, plugged it into the wrong plug ( some wires blue) and got a code, plugged it into the correct plug ( pink wires) , cleared the code and the bike ran, but super rich. Got to me, not mentioning the error. After a while I zeroed FL switch table, bike was fractionally better, so unplugged MAP and blocked hose. Bike idled at 13.4:1 AF. Plug in MAP runs at 10:1. New MAP coming in post. Give it a shot maybe, it cost nothing to try....I checked vacuum on each throttle body: All seem good, including the "suspects" #2 & 3! Needle oscillated wildly (as per your warning) but clearly shows good vacuum.
When measuring directly (not teed in) on the tubing feeding the MAP sensor, I'm down to practically atmospheric again.
Disconnected all hoses from the 3 into one fitting and measured vacuum on each body via its vacuum hose, good vacuum on all 3..
Pressurized the 3 into 1 fitting, no leak.
What witchcraft is at play here?
