warp9.9
Pocałuj mnie w dupę
No you have all three header pipes joining into one. follow it back to the first elbow down its right under where the elbow turn down engraved in the case right between the ribs on the top of the engine block you do not have to pull any shields. Let me knwo if you do not find it and I will take a picture and post it for you.cannot see anything from just looking at the engine as is , do I have to remove the exhaust? is it on the rear face of the motor or to the side close to the frame to engine bolt? when you write "under the exhaust header" do you mean below or behind because I cannot see anything remotely looking like a flat spot with numbers an d i used a BIG flashlight!!
Here you go you can see the location do not mind the dirt she is in dry dock
