Radiator and Clutch cover removal video
You are so right man.. We are playing the guessing game now..:confused: Now it explains why everytime I order parts the first thing I hear is "What's your VIN number..?" :D
Thanks again Warp for bringing that to my attention. Now I'm doing Valve clearances and I can't seem to find a Shim kit here.. Bummer man:( The dealers want me to exchange shims with them and I'm like No Thank you..!!:cautious: :roll:
Hi I get my shims from here good service and price is ok i think.http://www.precisionshims.com.au/
Alright guys here is another video. There's only 1 more after this one to upload. :laugh:
Watch "Triumph Rocket 3 Keyless and Valve Clearence check" on YouTube
Triumph Rocket 3 Keyless and Valve Clearence check:
G-Day Banny Lowie here {Brisbane} **** hot videos you make mate you have inspired me. with your help i have done the eastern beaver install and the starter relay mod on my 2010 Roadster I have just seen your clutch video and i am going to give it ago i had a Barnett clutch kit put in by a bike shop i am not happy with the job thy have done when getting home after picking it up coolant was licking from the silicone radiator hoses when going to titan them i notice that the bolts holding on the radiator also needed 2 be titan i have had 2 adjust the cable all the time to stop the clutch from slipping now i have no more adjustment left so it is time for me to have a-look may be buy another clutch kit and install it my self can you tell me were you got your kit from and the rubber o-ring or grommet for the water pump pipe and its size please have you been for a test ride yet after putting in the new clutch if so how did it go?PS:lots of good things come out of Liverpool some stay i lived in heckenberg for 20 years Keep up the good work Benny as you are appreciated
Trevor thank you so much mate and glad the videos could help you out.. :thumbsup: That's exactly what I intended for them.:)
GOOD OL HECKENBERG.. I use to love the fish and chips from Heckenberg shops.
It's unfortunate about the clutch problems you are having mate.. I wonder if they just used clutch plates and not springs..:unsure: Does it slip from take off or when you try to power up to overtake..?
I purchased mine of ebay here's a link
Check out this item I found on eBay: http://pages.ebay.com/motors/link/?nav=item.view&id=310900770154
If you can let us know what year your bike was built and Serial number of engine which is under the exhaust headers. There seems to be a few changes in engines for some reason. :confused: And a few guys here might be able to point you in the right direction with parts.:) In regards to testing the bike, I haven't had the chance yet. Still completing valve checks and a few bits and pieces. But once I do I'll post it asap:D
Thanks Watcher, glad you liked it mate. .:)
Warp, I just talked to mate about his Rocket. It was actually an early built 2005 with a black engine.. So I guess you can say that Triumph are trying to keep things interesting..:roll:
There was a problem with porous castings, Triumph sorted it so a few early ones ended up with later casings or engines.
Not saying that is the case here but it is possible.
Good vids by the way.
I cannot thank you all enough my friends.. You will have a laugh Gregger when you find out that i pack soups and Sauces into cartons for our local Grocers for a living..:roll: Sometimes i wish i traveled a different path, but i'm sure that i'm one of many..;)
Warp i had a look at the serial numbers for you and mine is 3249082. I looked at my build date for the first time and my machine is actually built 05/2007. Glad you brought that up, now i know mines a 07 model. I'll have to confirm this with my mate about the build time but there is a bike somewhere here in Oz which is an early or late 06 model and it has a Black engine. Before my friend sold it he tried buying parts for it and he had dramas trying to convince the guy that the bike came from factory with a black engine. So after a few calls to Triumph he got confirmation that it was a factory release and not a swap.. Strange jazz..o_O
And thank you too Warp for your input, please share all that you can in regards to this as it will help many gain more confidence and to lead them down the right path. Unfortunately there are many Motorcycle workshops who don't have our best interests at heart. So many of us are walking or riding away with lighter wallets..:(
where is the engine serial # located ? I have an 06 standard with black engine as well and knowing the # would allow me to make intelligent decisions when ordering parts, I already found many problems with triumph parts catalogue regarding my ride.I.E the rear wheel spacer for one!!
it is under the exhaust header rigght on the back sid eof th eengine where the header curls down to head the to cat box . before the O2 sensor. Most deallers will have you give the vin number of the bike though which is on the left hand frame tube or ingraved in the right hand side of the steering neck. It is usually on the insurance card and regisyration. they usually want the last 6 numbers.
cannot see anything from just looking at the engine as is , do I have to remove the exhaust? is it on the rear face of the motor or to the side close to the frame to engine bolt? when you write "under the exhaust header" do you mean below or behind because I cannot see anything remotely looking like a flat spot with numbers an d i used a BIG flashlight!!
