Quick Release Sissy Bar for the Roadster
Its a comin mate its a comin. Been a silly season again with what I do in the community. I will get onto it though, I will send you something before the weekend. Doing it tough at present my accountant is o/seas he he. ;);)
Yeah they want about $120 dollars to polish the brackets here in TO... and about a week to do it?? Seriously... I think I'll just leave them as is.
buy the spindle adaptors for your grinder get the buffing/polishing wheel (or as I did get both) get the correct compound for wheel and polish to your hearts content it will take a couple of hours for the size of the brackets, you will be surprised how many things you can polish with them.
As previously mentioned mine are available to use if you are in the area and Al if you like post them down here I will do them for you for free you just cover postage back and forth
KEEP US POSTED ! I want one as well !
I have designed the bracket and am currently cutting them out.
The front mount is slotted horizontally to stop any up and down movement and the rear mount is slotted vertically to stop any movement horizontally.
Once cut I will have to bent them to shape clean them up and have them chromed.
Check out the backrest/luggage rack that I made. It goes on and off with no tools. also it is reversible, meaning it can be rider backrest or turned the other way, a passenger backrest. check out the pictures in my pic gallery. Most of the pics were taken before it was completed, as far as the welding and cleanup. I used the stock Triumph saddlebag mounts, but I put a stainless steel spacer on the four mounting bolts. Then I used 1/2 inch solid 404 stainless steel rod to bend and form into the frame. This backrest bracket simply lowers straight down onto the four spacers, then four lynch pins hold it in place. no tools to remove. I will say though to reverse it you would have to switch the backrest pad and bag. that just takes an Allen wrench.
