tdragger
The exorcism of the ghost of Lucas has begun. BE GONE!! YE DEMON!!
I disconnected the EB kit from the main harness and checked voltage at those points. Everything checked out perfect. I also disassembled the dimmer switch housing and everything checked out there, too. Voltage on the low beam circuit when it should be and voltage on the high beam circuit when switched to it.
Reconnected the kit and pulled the relays on the EB kit to check the sockets. Everything good. When switched to low beam I got voltage on the line side yellow pin and the red pin (power source connected to the PC-8 and ultimately the battery). On the other (white) relay socket I got voltage on the red pin only as expected. When switched to high beam, the appropriate voltages showed up where they were supposed to.
The fun begins when one or both relays (tested both ways) are plugged into their socket(s). With the low beam selected, I would expect to see voltage at the yellow wire pin in the H4 connector. Nope. The voltage shows up on the black wire pin in both bowls. ??? On high beam, the same occurs. Voltage on the black pin but not on the white pin.
And the weird thing is, back on the wiring harness I get voltage on both the low and high beam circuits!!
Obviously there is a short somewhere in either the relays, H4 connectors or in the wiring downstream of the relays. Taking a break to get some more Holy Water.
