Joesmoe
IMOKUR2
Now that I understand my borescope, I will make a concerted effort this weekend to rotate each piston *down* giving the borescope room to view the entire piston top, just to rule out any foreign object that could have entered the cylinders during the work.
If that checks out, I've pretty much run out of anything I did to be an issue, and will carefully re-mount the clutch cover being ever so careful to follow Nev's supplemental instructions to ensure engagement of the actuator arm with the lifter, and, give it another go.
This will not be this weekend, because I really did NOT like the looks of about half of the 24 bolts that hold on the clutch cover, appearing to be identical to the bolt I rounded off in replacing the throttle body adapters, so I've ordered a complete replacement set from Hermy's.
