Innovv K5 camera system
Follow any wiring harness up to the front windshield/panel and come out from there. Golden.
Is it possible to tie to wiring harness without removing the gas tank? I'll look again, but when I looked this morning, it was not evident how to tie up to that
Definitely run it along the left side. The right has all the coils and a lot of other obstructions. The first time I did it without removing the tank by taking a long zip tie (or a stiff wire) and sliding it on the left side (front to back I believe) keeping it high. You'll go over the rubber tank brace that is near the middle of the tank. Now if you secure it high up on the front with a small zip tie, so that it doesn't hang down and find the best path out where the tank meets the seat you'll have it- good enough. Mine has not shown any signs of melting (over 20K miles).
Since then when I had the tank off I added a couple of zip ties to the frame but it really wasn't necessary, just looked a little neater. Here's a photo showing what's under there, including my wires for my front marker lights and the camera wire....
Thank you! This is perfect!
One more question... :)
For the rear camera, how did you route the cable from under the seat (assuming along the transmission) to the license plate area? I can't seem to get it clean enough
On an unrelated note, took the rocket out for the first open back roads ride this morning - holy moly... The torque is insane (and that's despite me being careful to stay under the break-in guidelines since I don't have 600 on the odometer yet)
The support rails are open on the backside. I might heat shrink that fat connector just to make it very waterproof. No probs in 5k miles though. Undo that one bolt and go under the mudguard. There is a perfect mounting bolt under the turn signal stalk.
Just wait until you pass the break in period. 🙀 Miles of smiles! And another 🙀 when you add the Penner tune and really let her shine!
Thank you - those pictures are perfect!
I will read up more on the penner tune, but given I have the storm version, I suspect I may not need a tune at least initially 😜 I thought most ECU maps were to open up the non-storm R3 to the 180Hp. Guessing the penner tune does more than that - I will read up once I get back
No prob, This board is great to get answers for Triumph idiosyncrasies that are sometimes baffling. I think you are right that the Storm did away with the 1-3rd nanny and opened up the map. You are in for a treat after break-in!
Write your reply...
