just an opinion
i think that u have installed the secondary tps wrong so this means u probably messed something up.
installed wrong it might take out secondary tps or the secondary motor (gears).
IDK has manuals listed for the early rocket manuals posted to down load.
i have been looking at the tps on page 11.129 thru 11.132. now i think that the primary tps shows a little discrepancy in the drawing the way it tell u how to install the tps.
if u have a screw up then it is hard to tell what is wrong. now this may be a little hard on u but u will have to start listening to us and doing what we say in order for us to help u.
1 pull the air intake system off so u can see the secondary butterfly's.
2 pull the secondary tps. put a screw driver in it and gently try to turn it. is it spring loaded and does it return to stop position on its own? is it the one with the long wire (correct secondary)?
primary and secondary tps will not interchange.
if the answers to #2 is yes open secondarys wide open then turn the tab (that engages the tps) counter clockwise
(gently) until it stops. then does the secondary tps look like it would fit like in warps post #36.
the bad news is that the secondary motor is not sold by its self u have to by throttle body asy or find a used one.
