warp9.9
Pocałuj mnie w dupę
So from your post especially above I can not tell but it looks like they have not even check the ISCV. This is a easy check as if things are set right you just click by and keep going thru it. If I were a tech I would do that first as thing can't run right or optimum if they are off more then the tolerance. If I found something was off then I would start with the chain mechanical and electrical.
First verify throttle cables are set with the right free play this is checked at the throttle grip for the pull cable and down on the throttle wheel for the return cable. 2-3 mm I would hang with 3 mm to make sure. once I knew not of the cables were binding (to tight) and why I was down there I would probably notice this
one side spring relaxed one side spring tension-ed / throttle flaps move within this range yet the cable grip does not. Lets think a while so we can star adding other possible unwanted spring tension movements to it. Mind you this is not something in the book so the tech does not really have a description of the full operation of the complete set of throttle bodies bolted in a chain.
