ZoneIII
On a related topic, do you have to remove the rotors - or at least one front rotor - to change the tires with spoons? I've asked this question on two forums but haven't received a clear answer. The answers I have received were that people didn't think you had to remove the rotors or that they had changed tires on completely different bikes and didn't have to remove the rotors. But I'm asking specifically about the R3T. I'll be changing the tires next month and the front rotors look like they may be in the way of tire spoons.
So, has anyone here changed their R3T tires themselves (not had it done by someone else)? Did you have to remove a rotor or rotors?
Also, the factory service manual says that, if you do remove the rotors, you should replace the rotor bolts. Is that really necessary? I know thread locker was used on them but that can be cleaned up.
