Free unrestricted maps for Rocket R GT and TFC now online
......so i downloaded the unrestricted map for the 'R' model but it wont open because its...'unsupported or file is corrupt'...whats the story?
You’re getting the all markets
R map off of TuneECU.net? It’s a zip file. Did you unzip it? If so, is the app not reading it?
I just did this, copied it to my Kindle Fire tablet, and read it into TuneECU. Are you sure your app and bike are registered?
i have previously used it ...downloaded tunes and tuned bikes...its just this time....i must be doing something different..hmmm
I understand. I looked at these when they came out. I thought this all markets tune might be a revision of Penner’s original.
i havnt used ecu for a while...must be loading it wrong...my lady's son is a computer tech...he may be able to sort it over the weekend if i dont get a brainwave soon!...frustrating tho!
So a few things:
1. Make sure you install the latest TuneECU software .apk direct from their website, don't stick with whatever old version you may already have had installed
2. I am assuming you have a decent BT OBDII device if you've flashed other bikes. The OBDLink LX, MX, MX+ ones are what TuneECU recommend. I used the MX+ with no issues.
3. I think you want the "All Markets Rocket GT No Restrictions 31012Map.hex" as you have the GT ("Triple Black" in your sig rather than "Black" for the R) right? I ask as you say R a few times above. They use a slightly different map, 31012Map vs 31018Map. It's in a zip file, but to test it I just downloaded it straight to my phone, extracted it with the Android files app, and opened it in TuneECU (v5.5.24) and it read it straight away. So my phone has successfully opened the 31018Map I used on my R, and just now the 31012Map that is used on a GT.
For loading:
4. Make sure you have a battery charger attached so the voltage doesn't go too low and the ECU shut off halfway. It takes 10-15 minutes to load the map which will give the battery grief. They say to pull the headlight fuse, but that doesn't kill the LED DRL's, so switch them off manually.
5. After the load, do NOT use the "reset adaptions" routine as it resets the crank position sensor throwing a code, and you need to then run the calibration procedure (I describe it in another post here).
6. Ride and enjoy!
If the previous poster wanting to know how hard it is is interested, my walkthrough of it (including my reset adaptions cock-up) is on my channel:
So a few things:
For loading:
6. Ride and enjoy!
LEGEND!...Thanx very much....alot of this ive done already as i have downloaded tunes and installed them. It seems as tho i have to infact download the new TuneECU...i still run the old version. My cobber has the 'R' model and i want to throw the unrestricted tune in his bike...i already have it in my GT. I think things have changed in the download area such as the new version. I will follow your advice and see how i go...could be a whiskey in it for you...lol!
Common problem, newer maps aren't read properly by older versions. Git 'er done! :cool:
Just watched your vid...good work!.....explains alot of things very clearly so watch this space! lol!...i actually loaded the original hot tune into my previous 2020 GT so was able to put it into my current Triple Black as i had it in my phone...but seems the updates have happened since then...Thanx again...will let you know how it pans out...cheers.
Write your reply...
