Engine rebuild gone west
On a serious note...empathy....you are lucky to have found the issue before too much damage was done! My v6 diesel has just spun a big end bearing after identical symptoms to your bike..$11/12k rebuild :banghead:
Its always funny when it someone else is what I say😁 this time it's on me....welcome to the club Mr Hunt
A melancholy moment for sure😳, they overlooked this on original rebuild hi when it had thrown a valve on cylinder 1 they replaced the piston and head and had low oil pressure on start up they replaced the oil pumps and it still had the same problem, I open it up and walla, I was hoping they'd missed an o ring BUT its like they forgot to put the piston rings on..... I will be replacing the big end shells sleeves and new rings that should seal the deal
Since it's found in this condition, I wouldn't take anything for granted. Give all parts and systems a through check. No telling what else could be screwed up.
You recall them times when you say to yourself it couldn't possibly get any worse but it does.. Amazing thailand
Write your reply...
