Bigger Headers on 2.5
Absolute numbers are good if you can equally compare them. Personally what I like to see are what the gains were relative to baseline.
For example (made up numbers).
  • Stock: 140 RWHP (baseline)
  • With just a tune: 170 RWHP - 21% increase over stock,
  • With header & tune: 182 RWHP - 30% increase over stock, 7% increase over tune alone
So, while I love the headers, incrementally, it doesn't potentially make a lot more than just a tune alone. At the same time, it would likely be the cornerstone to build upon and another ~7% is nothing to sneeze at. So the low-hanging fruit is going with a tune. At the same time, if I go with the headers, I'll need to spend some $$$ on dyno time to get it right or I am leaving HP on the table.
I priced dyno tuning in my area, and I got quotes of a minimum of $500 USD to $1000, depending on the shop I went to. So I'd have to add that into the overall cost. Now if there is a map already that would work with the header for TuneECU then I could save on that expense.
Despite the economics not being as good as I would like, to hit my goal of 200 RWHP, it will likely be necessary. So there is a header about to go in my cart. I am just debating between the stainless or Ti version. I wouldn't mind the few extra pounds weight savings. I am assuming there is no difference in output.
do you still have stock air filter and is o2 sensor still on that exhaust?
US$500-1000 seams excessive !
The dyno tune done here by BRM was around NZ$500, that's US$306
When you say a tune only, that would be a "canned" tune, so not nessarily 100% correct for your individual bike, fuel, ambiant conditions, right ?
In the past people would ask me for a tune to go with my headers, this often caused grief as the tune that I had here for NZ conditions, fuel etc didn't work so well with the different fuels etc Globally.
I no longer do this.
Shops in my area (Texas) charge at least $150 USD hour to do anything. So for $500, that was the cheapest I could find that didn't work on just Harleys. As for the tune, yes, a canned one such as Penners which seems pretty safe. BT Moto is about $890 or so but that includes the device as well.
My goal is to get as close as possible to 200 RWHP with just bolt-ons and no spray.
Richard Albans posted a video here in which he said the stock headers were the biggest restriction.
How did you dyno tune it? Power Commander or directly with Tuneecu? Not everyone has access to dyno tuners. Can you offer your tune as an accessory to your hardware.
I'm not sure what programs Brett uses to access the ECU.
No I don't supply tune, as mentioned in another thread, a tune I would supply is for NZ conditions, fuel etc.
This has caused grief in other parts of the world with the different fuels etc.
A canned tune is never 100% correct for your particular bike, fuel, climate etc.
Would you use a Power Commander or tune it with Tuneecu?
Besides performance benefits, does the larger headers and difference in design significantly reduce the heat output or is the difference in that regard negligible? Just curious.
Using the figure of 25% loss that makes the real world RWHP of 182.5, 250 HP at the crank. Do ya think ?
A 20% loss would mean that RWHP of 182.5 would be 230 HP at the crank.
Choose your own numbers.
What ever the crank HP is, the RWHP as done at BRM Tuning in Paeroa, NZ was 182.5
sure! my cousins has a friend with an uncle and on “that dyno” we get 300RWHP…
I think all of the aftermarket header systems allow you to feel more heat. I’m not sure if the heat output is higher but you will feel it a lot more.
There's a lot of "interesting" opinions stated here.
We built a header for the 2.5, had it tuned properly, 215 crank HP. That's a 35% increase over stock.
No other mods.
So for those who say "just a header won't make much difference" you're way off base.
@Nashvegas here ya go! Meet the viking
Exhaust pipes are hot, a lot of people don't seam to understand that concept.
Nothing will "reduce" the heat coming off a fire.
When people talk about "Hotting" an Engine up, that is eactly what happens, you increase the air/fuel you are going to increase the fire,.
The more fire you have, the "Hotter" it will be.
