Joesmoe
IMOKUR2
@Joesmoe was the wiring long enough or did you have to extend it??
@Jag - The beauty of this installation as you see it, is the replacement unit is truly plug and play. Unplug the connectors from the OEM R/R, and unbolt it (two bolts). The bracket also has the tip-over sensor on top, and one doesn't have to do anything with that. The existing wires come from the front, and so they easily turn up to the location you see.
Short answer: Yes, the wires are long enough.
