How many rocket III have had ignition switches fail or kill button
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
number 1 there has always been a debate on whether to first turn on the key first and then the kill switch
number 2 or have the kill switch on and then turn the key on
i know that the lights took out a lot of ignition switches between 05 and 2010 give or take a couple of years
i installed a couple of relays for my lights way back and always turn on kill switch last so as to save my ignition switch and so far both have held up good
so tale your ignition switch stories
do you have an idea what caused it to get hot enough to melt the solder?
Memory is a fleeting thing. I looked up my old post and the wire was actually broken about an inch above the solder. Not sure how to explain that...
Put a deCosse keyless early on in my 2012 R3R no problems to date.
Stock ignition still in my 2011 R3R - no problens to date.
Mine took a dump couple of weeks ago 80k miles on clock ,not solder problem it's internal in the switch . Done the relay thing years ago . I don't think it's too bad for a nearly 20 year old bike . considering whether to buy a new switch or just drill the side panel an fit something cheap off e bay. Using this at the moment
