Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
I'm a day late but here's the graph. This is my bike, if I were to only up the stroke to 4 inches with NO other changes. There are things to optimize and maximize the gain of stroke, cam timing, intake diameters/length, exhaust dimensions etc. These are CRANK measurements, mulitpliy them by .875 for fairly accurate WHEEL measurements.
Mufasa 2.3 --- Mufasa 2.5
213lb-ft --- 227lb-ft
273hp --- 276 hp
As you can see, there are clearly other restrictions and flow bottlenecks, indicated by the 6200 RPM+ roll off in power, which is why they end up essentially at the same HP. The stroker is making 133lb-ft by 2200 RPM, so right at cruising legal speed range in most places, and will be enjoying a nice EGR effect from the big cams. I suspect this would be like a 45-50mpg setup for touring.
273hp --- 276 hp
