Step 3: Measure up engine & transmission internals
2.5L Stroker Update
So after rolling the R&D engine over and tearing it down with impunity, we found that there is ample space around the moving crank and rods to permit a stroker engine. Loads around baffle plate and liner and skirt and rod clearances.
To cut to the highlights, it gets pretty tight in a couple places; the gearbox crankcase wall at halfway between TDC and BDC for throws 1 & 2, and between the crank counterbalances and the balancer shaft.
Tightest gap I found was 3.0mm, which would kill the proposed +3.65mm crank throw increase,,,,, but I have a clever idea (or at least i think it is
) to make the +3.65mm happen. If it works better than intended, more than 2.5L will be doable with just crank and rods.
This is how a sad-act like me spends his holidays;
Throw increase of 3.65mm brings stroke up from 94.3mm to 101.6mm to net 824cc per cylinder (up from 765), making a 2472cc or 2.5L engine.
Just to reiterate, the idea behind 2472cc and not say 2499cc, is that the bore is 101.6 so bringing stroke up to 101.6 also will make a "square" engine, like a Dodge Viper or Bugatti Chiron.
Also found a fabricator who is making the side panel badges, so they're OEM looking but say 2500cc instead of 2300cc.
Yeah it's a lie as it's 2472cc and not 2500, but the OEM badge says 2300 when it's actually 2294 (2295 by my calcs), so fcuk the po-lice!
Verification of stock displacement
Done some research on piston speeds and apparently about 25 m/s is more or less the industry standard for max piston speed in sporty engines, but can be around 20-21 for big pistons like ours;
- Stock Rocket III (94.3mm stroke, 6300rpm) = 19.80 m/s
- 2017 Dodge Viper (100.6mm stroke, 6250rpm) = 20.96 m/s
- 2018 Bugatti Chiron (86mm stroke, 6700rpm) = 19.21 m/s
- Gen II Hayabusa (65mm stroke, 11500rpm) = 24.92 m/s
- BMW S1000RR (49.7mm stroke, 14200rpm) = 23.53 m/s
- Yamaha R6 (42.5mm stroke, 17500rpm) = 24.79 m/s
- Typical F1 engine (42.3mm stroke, 17900rpm) = 25.24 m/s
- 9k Carpenter Rocket (94.3mm stroke, 9000rpm) = 28.29 m/s
- 2.5L Rocket III (101.6mm stroke, 6300rpm) = 21.34 m/s
I guess, for me, running a 2.5L Stroker Supercharged Carpenter engine at 9000rpm will mean peak piston speed of 30.48m/s
which is a bit above what factory engineers would like.. but maybe race engine builders probably would be too afraid.
6300rpm guys will be 100% safe at 21.34 m/s.
Figure if the engine spends its life below 6500 then what's the difference - occasional jaunts up to 9000 might be harmless
Starter map is ready, 2 minute job, added 8% air across the board in the F trims and applied to both F and L tables. My estimate - 2472cc is about 8% more volume than the stock 2294cc, so 8% air quantity added to F tables.
And 101.6mm is about 8% more stroke than the stock 94.3mm, so estimate is 8% more vacuum pulled, for the L tables. It's a place to start at least.
So now we're in the middle of Step 4, design new engine parts.
I've spec'd up what is required - won't post until the design is final with the approved vendor.
A number of crank & rod fabricators in both UK and USA have been engaged, so we'll see what the damage is...... it's not looking good though, most of the $$$$$ is for design and setup costs
6th Gear Update
I may be a bit of an idiot,,,,,, but upon opening it up it became apparent real quick that Triumph used parts from a 6 speed gearbox - look at the detent wheel;
It has 7 positions, 6 gears + Neutral!
We only use 1-5.
And the selector drum it indexes around to change gear has a convenient "blank" space between 5th and 1st, for the future 6th gear fork track!
Plus the GPS has the same 7 positions also!
(have a photo somewhere of gear 6 on the tacho display)
Clearly, the box is structured like a 6 speed tranny, but with 5 pairs of gears in there.. guess Triumph wanted thicker gears to take the torque etc, but why is 4th so thin
or maybe 5 gears was just because marketing said so.
So now we have the track map design of the new selector drum;
Ever want to see Rocket transmission in action?
Also gone out to a number of gearbox masters in UK and USA with the proposal, initial estimates are it will be like 10 G's to do the 1st one
but cheap thereafter.
But my plan is to shave 1000s off that by designing/building the prototype myself from aluminium, just to prove (to some degree) that it will "work", before cutting real gears and modifying shafts.
More on that later.
Art.
