Widowmaker Journey to 200hp, no thats been done. 250hp !
Hold the dyno Konrad! Our heat soak, loosing horsepower problem has been answered by our racing suppliers in Australia. Its on the way, and i will sleep well now, knowing my Lush Racing Head will have a professional racing cooling system to take care of him, Thanks Les LMS Motorsports
Ive been rocking the $225 i think, Chinese one, that does work, but its hardware and material kinda cheesey bendy, its a 225 radiator, stock 1200, PWR is professional and a very good price we’re gettin. cheaper than stock, its an improvement over stock like the samco hoses that are cheaper than stock but an improvement. The dyno will tell even if its 30 degress out because Konrad goes through 1 and into 2nd five gallons when tuning on dyno, so its gonna go hot but i have the 165 degree thermostat from Australia, ofcourse hello, 😂, will see, heat most definitely robs horsepower, you can see it when tuning you think know you made change to get more but fing heat, thats what ive seen watching Konrad and cussing, i know by that too, @Gerald Konrad said he lost ponies like on mine when he tuned you up, how’s yours running since? once it gets around 185 it struggles making power, heat is an engine builders enemy😬 learnin 😂
Normally I would say going to a lower temp thermostat is not the best practice especially when you're dropping it so much. You would probably drop you gas mileage and cause your 02 sensor to seldom take effect. Now that it's been said...
Given the fact you probably have the sensor already removed and are going to race the machine, it shouldn't be an issue. If the average temp actually stays at the rated 165 F because of that beautiful rad (It's the rad that lowers the temp, not the thermo), you will be able to run a richer mixture, get potentially more power and advance the timing a bit more. Also helps with running higher compression pistons. Looking forward to those dyno numbers.
I must say i dont know much about it really, on a fast train learning though, but stage 1 for sure rookie status, ive tried to make changes that fix problems the tuner encounters with the widowmaker , this is 4th tune and i hope issues weve come upon are corrected and i didnt make problems which i know happens often with rookies actually worse. Ive changed alot, but some of the best in the world are keeping an eye on some of the stuff i think will work😬, and will say that wont work 😂😂😂 if I’ve screwed the pooch trust me im fixen before i tell😬
The stock radiator wasn't up for the task? You did hook up the water pump? 😂
