Widow maker journey to the 200hp club
It all started here you have to read a few posts to see how it progressed. RAA East 2020 West Virginia
My recollection is that someone suggested he paint his motor pink, like a Barbie doll.
I then started to refer to him in posts as "Barbie".
The member formally known as Kevin, is paradoxically and ironically a polar oppisite of BARBIE. Barbie is beautiful yet stupid . . .
My question is how will the compression test work if both spark plugs are removed as Speedy said to do ? I'm lost on this.
Remove all so engine turns faster, insert 1 spark plug into cylinder to be tested and the gauge in the other side of same cylinder, 2 pages back Gerald answered this, fast moving thread.
Go ahead and say it don’t end it there, ‘ And Kevin is handsome and smart.‘
If you go back the the post I linked, you will see how the reference started. RAA East 2020 West Virginia
Look here GOC, long and black just like johnnys Cadillac
Here Ya go, fixed it for you
Compression test done, cyl.1 250, cyl.2 255,and cyl.3 260. I did this 3 times 1,2,3 1,2,3 1,23, the cyl 1 did 252 255 250 cyl 2 did 255 255 255 same just about needle is not digital and cyl 3 260 258 260. New plugs being fitted and off to dyno soon. This part is an edit, compression tester test 15% high on readings when bench tested, Probably will never know accurately without a proper tester but for me, it seems I didn’t pooch the bedding in process.
Congratulations, very consistent. What plugs are you using, and heat range?
