Planet3
.060 Over
- Joined
- Mar 28, 2022
- Messages
- 122
- Ride
- 2021 triumph rocket 3R
Whats different today than yesterday is it was dead yesterday. No horn, hazards, immobilizer light, accessories, nothing....The way Triumph stacks the electrical connections at the battery causes some corrosion to form between them as they loosen. I had the problem. Take a wire brush and clean both sides of each spade and coat with di-electric grease before reassembling. When you have them tight, go another half turn. Then another half turn if they loosen again. I thought the bolt would break the last time I tightened them. But once I had my battery terminals dogpoop tight I quit having all sorts of problems.
Today when the button is pressed upwards it lights the dash and primes the fuel pump. Then I press the starter and all blank, nothing.
Then I'll turn off my keyfob then turn on again, hit accessories on the starter then I stand back as it flickers on and off with all sorts of buzzes and noises from below the fuel tank and at the rear of the bike. Its literally like a disco nightclub going on off on off on off on off all within split seconds. Yet when it does crank over its not even a lazy crank. It cranks and starts like a brand new battery. I'm thinking my bike may be possessed!!!
