Unrestricted map for Rocket R and R Black from VIN # AV5457
I have made an unrestricted costum map for the actual Rocket R. VIN AV5457 and up.
It will be at Tune ECU in the costum files section.
it is USA and Canada market only.
The other models and markets will come in the next few days.
ETV2 and 3 are set to 100% with a little more progression in ETV2 at wider throttle openings.
F and L-tables are changed for smoother running at low loads and revs.
AFR target is modified to keep it like that.
Don´t make a reset after loading the map.
But the 12min idle reset is okay.
Any feedback is welcome.
Prost
Ulf
Dear Penn
I have a 2023 Rocket 3 R, VIN SMTG11JX7PTBF1956
I experienced serious engine stall issue when on 2nd or 3rd gear, when accelerate and pull clutch to shift up/down. This almost kill me on highway.
Currently I am looking at TuneECU 31255Map.hex (Also says for AV5457 and up), is it compatible with my bike, and can it solve my issue?
Big Thanks!
Dear Penn
Big Thanks!
Depends where you bought your bike. Your problems with the bike won’t be fixed by a tune.
Dear Penn
Big Thanks!
Yes, the unrestricted map will work.
But I agree with Dougl.
Looks like there is some other issue.
Prost
I have a '23 GT (South Africa) with Vin ending with BC1505. Is there a Penner map available for this bike? (can it be this one: Unrestricted Map 31248 all markets for Rocket 3GT/GT Black from VIN AV5457 ETV/F/Afr Tables modified 7400 Rev limit). I assume there is a noticeable difference in performance between the OEM map the Penner map?
Regards!
South Africa is part of a market with Argentina and Indonesia. The base map is 31253. You could take the GT map above for all markets and copy the tables into 31253. Only the tables that are different which are F1-3, ETV2(1-4), ETV3(1-4), and AFR.
Thank you very much! I understand it is no more advised to do Adaptations after mapping? Just do the 12 min idle after remapping? Regards!
I bought from California as new bike. Could you be more specific on why you think a tune wont work?
My bike is bought from California. So how 31255 is different from the stock map?
Thanks!
31255 is the stock map. This is Penner’s unrestricted map. I didn’t say the time won’t work. I said the tune won’t fix you problem stalling on the highway in 2nd and 3rd.
