Unrestricted map for Rocket R and R Black from VIN # AV5457
Penner doesn’t have a tune for the UK. Did you just load the stock 30254?
Oh, maybe! What a numpty! I went into the download section on the app and found the one that matched mine.. Thinking about it now, it would seem I did load the stock map!
I'm guessing I have no option for a Tuned file yet then?
Actually you do. I copied the Penner tables into 31254. PM me your email and I’ll send you the map. By the way, don’t do reset adapt. It messes with the crank position sensor.
Wow that's ace, have you used it yourself?
I will PM now.
I will PM now.
A lot of people have used Penner’s maps. They derestrict the electronic throttle giving full rear wheel power (170 hp) at wide open throttle. I don’t know if anyone has installed the latest R3 map that you got from the app on a 2024. But you said you installed the 30254 stock map. I presume it runs with no problems or CEL codes? If that’s the case, the modified 30254 should also be OK.
Hi, I have a Rocket 3 R year 2022 with VIN AZ9884 EUROPE. Does anyone know if there is a compatible Penner map that I can install? And what will change in terms of horsepower and torque?
Thanks
Best regards
Alessandro
Thanks
Best regards
Alessandro
It’s on Tuneecu.net, custom 3/4 cyl maps. It’s the modified 31254.
Write your reply...
