Unrestricted map for Rocket R and R Black from VIN # AV5457
I’m new at this and just got my bike. My bin sta””is AE.6140. Does that mean I can not use this map? Thanks. Ben.
That’s right. But you can copy the revised tables from Penner’s new map into your base map, then load it.
I have a 2021 Rocket 3 GT. Are there any unrestricted maps available for VIN AE6140 that will work? Thanks
Hallo Ulf, wie gehts?
I'm living in the US and will be getting my new 2024 Rocket3 R in April. I've been educating myself on basic TuneECU workings like unrestricting and simple things and getting the geeking out done with ahead of time. Everyone seems to really like your work so I'm wondering if there is any way of telling whether or not the map in question will work with the 2024 model? Also I'm having a really hard time finding the map you talk about above.
Hello Protonhound, Danke mussja.
There is a chance, the 2024 models will have a map, that is not (yet) covered by Tune ECU.
To be sure you will have to connect Tune-ECU to your diagnostic port. It will then show the number of the map. If it fits any of the costum maps you are fine.
But we will have to see.
Cheers
Ulf
Your base map for S Africa is 31253. You can download it in the app. Then you can copy the tables from Penner’s new GT map into 31253, save it and load it.
so I'm eventually crossing this bridge. using the app for rocket 3 gave GT so the only option is the one for AV5456? However I found only 6 maps 31012 through ...17Map.hex files - no 31253?
I've downloaded 31253 and is said for SA? so dont worries, think I came right
If your vin is above av5456, 31253 would be the map for S. Africa. However, you should confirm that this map is the one in your bike. When you connect to the ecu the first time (internet connected), a window should pop up showing the tune in the bike.
P.S. Oops, Penner said this in post #26.
What do you mean by "internet connected"?
