Valaas
.040 Over
Hi, I am finally sufficiently motivated to convert my 2008 Classic to FA by turbo.
Tried to do my due dilligence, and have read whatever I could find on the subject. But I am relying on a friendly crowd. I certainly know the enginuity and wisdom is available here
Purchases:
-Aerocharger 8 psi
-Turbosmart GenV 40mm wastegate
-2 Bar MAP sensor
650cc@3 bar injectors
Walbro GSS342 255 fuel pump and stock/3bar regulator
-Stock header
-No intercooler
-PCV AT (0-5v input from MAP sensor) + Dynojet Pod 300 (realtime AFR view+adjustment)
-Barnett heavy duty clutch kit
-TTS forged low compression piston kit
-misc OE parts incl piston ring kits, conrod bearings, head gasket etc.
Way. way over initial budget. And counting.
Purchases:
-Aerocharger 8 psi
-2 Bar MAP sensor
-Stock header
-No intercooler
