New owner of an 05 roadster w/ turbo
Tucked right under the exhaust. Can’t even notice it unless you get low under the bike. Definitely noticeable when the throttle twists or you let off and hear the blow off though!
Thanks!
It's about the most factory looking turbo install I've ever seen. They used most all of the factory intake and exhaust bits it looks stock. Got any close ups of the intake plumbing and turbocharger for us motorheads. Which turbo did they use?
Here’s a few shots of how the turbo is hooked up.
Also discovered there’s A power commander V, fuel infection module, and auto tune. Hopefully I’ll know more after it goes into the tunning shop about why the auto tune isn’t autotunning.
Well after a trip to a tuning shop, it looks like they identified my issues.
Turns out the power commander 5 the previous owner installed wasn't installed correctly (Had 1 wire hooked up wrong), but the bigger issue was it was located in the right side panel where it got too hot. So the bike wasn't overheating, but the PC unit was and shutting my bike off when it got hot. I now have a new power commander 6, they relocated it over the battery, and gave it a new a new tune. Now it dynoed right around 180HP and 207ft-lbs of torque (This is at 4,600' elevation, should make more boost around sea level).
More than anything I'm happy to have my rocket back and hopefully have it be reliable now.
