TuneBoy is HERE!
DCRocket said:
I'm running the 20144 with stock filter and D and D exhaust - plenty of popping on decel. Will be downloading a tune R34ME perfected based on 20050_2 for the D and Ds - when I eventually can get a friggin day off
Gary, take a look at the sec table - you're gonna want to change that for sure if you want full power in all gears. Also Wayne's speedo correction might be something you want to consider. Alternatively, try tune 20050_2 and make changes from there
These are just suggestions without knowing your bike or setup - please do not take this as sound advice. I'm sure the knowledgable gurus will be along shortly
Okay . . . I loaded the new tune . . . seeing it was cold I'm doing a 12 minute tune as well before I take it out and see how different it is compared to the 44 tune.
Let you know.
Thanks
Gary
Took it for a spin . .. can't tell a whole of difference . . . even with the 7% added back on the bottom 2 gears it still is very controllable.
It has a little more popping during decel . . . not sure why . . . should be richer.
Speedo seems a little less than before.
Runs good, Idles a little harsher I think.
We'll see . . . gotta ride it more.
Goes on Dyno Saturday I hope . .. the I can see where it's at . . . then all I have to do is figure out how to change it and in the right areas.
Gary
Download the new tune in TuneEdit, open TuneBoy and hit reset adapt, start bike and let it idle for a while, then go for a ride - this is the same as running Triumph's 12 minute tune, but quicker. You do not need to do this when making small adjustments to tunes - only when downloading a completely new tune
I know R34ME added some fuel in the lower L tables to conteract the decel popping
See above post for suggestion on alternative to 12 min tune
I may go back to the 44 tune and see if I can just change up the 7% and speedo.
It seemed to run better on 44 tune. It's hard to tell about power gains . . . this things so dang strong anyway, you'd need a major difference in loss or gain to tell the difference. :twisted:
But I do appreciate the Tune Edit advice. Quicker than the 12 minute tune and more economical as well.
Gary
